BOnjour voila ce qu'on a changé
C1 – Capacitor, 820pF, Axial Ceramic – part marking = 821
C2 – Capacitor, 820pF, Axial Ceramic – part marking = 821
C3 – Capacitor, 0.01uF, Axial Ceramic – part marking = 103
C5 – Capacitor, 4.7uF, Tantalum, Dipped – part marking = 475
C13 – Capacitor, 0.01uF, Axial Ceramic – part marking = 103
C80 – Capacitor, 0.01uF, Axial Ceramic – part marking = 103
CR5 – Diode, Switching, 1N4148
CR7 – Diode, Switching, 1N4148
CR44 – Diode, Rectifier, 1N4004
R1 – Resistor, 8.2K ohm, ¼ Watt, 5% (Gray, Red, Red, Gold)
R2 – Resistor, 120K ohm, ¼ Watt, 5% (Brown, Red, Yellow, Gold)
R3 – Resistor, 8.2K ohm, ¼ Watt, 5% (Gray, Red, Red, Gold)
R11 – Resistor, 82 ohm, 2 Watt, 5% (Gray, Red, Black, Gold - or blue with value printed on it)
R12 – Resistor, 270 ohm, ¼ Watt, 5% (Red, Purple, Brown, Gold)
R16 – Resistor, 2K ohm, ¼ Watt, 5% (Red, Black, Red, Gold) – For Bally and Stern MPU-100’s
R16 – Resistor, 2.2K ohm, ¼ Watt, 5% (Red, Red, Red, Gold) – For Stern MPU-200’s
R17 – Resistor, 150K ohm, ¼ Watt, 5% (Brown, Green, Yellow, Gold)
R24 – Resistor, 8.2K ohm, ¼ Watt, 5% (Gray, Red, Red, Gold)
R28 – Resistor, 8.2K ohm, ¼ Watt, 5% (Gray, Red, Red, Gold)
R29 – Resistor, 470 ohm, ½ Watt, 5% (Yellow, Purple, Brown, Gold)
R107 – Resistor, 3.3K ohm, ¼ Watt, 5% (Orange, Orange, Red, Gold)
R112 – Resistor, 1K ohm, ¼ Watt, 5% (Brown, Black, Red, Gold)
R113 – Resistor, 2K ohm, ¼ Watt, 5% (Red, Black, Red, Gold) – For Bally and Stern MPU-100’s
R113 – Resistor, 2.2K ohm, ¼ Watt, 5% (Red, Red, Red, Gold) – For Stern MPU-200’s
R134 – Resistor, 4.7K ohm, ¼ Watt, 5% (Yellow, Purple, Red, Gold)
R140 – Resistor, 20K ohm, ¼ Watt, 5% (Red, Black, Orange, Gold)
Q1 – Transistor, 2N3904 or 2N4401
Q2 – Transistor, 2N3904 or 2N4401
Q5 – Transistor, 2N4403 or 2N3906
VR1 – Diode, Zener, 8.2V, Part Type 1N4738A (Alternate for 1N9598)
Quelq'un a une idée ???
Sinon j'ai refait les connectiques de la carte d'alim :
et voila les tentions :
* TP1 = +6.20
* TP2 = +152
* TP3 = + 11.92
* TP4 = 7.3 vac (illumination générale) j'ai rien
* TP5 = 49v
Pour le point de masse j'ai pris le support du transfo !
* TP1 = +6.20
* TP2 = +152
* TP3 = + 11.92
* TP5 = 49v
