4.15.2.4 Popping, Scratchy Sound, Very Hot LM1875 Heat Sink, or Shorted Speakers
Sometimes, the tantalum/ceramic caps in the amp circuit fail too. This can result in too much AC "ripple" feeding the amp as well as DC output to the speakers, which they do not like. C20 (10uf, 20V tantalum), C46 and C47 (both 1uf, 35V tantalum), and C23 (.22uf, 10V, ceramic) are all suspect.
Normally, the positive side of the tantalum cap at C26 will measure about 50mv of AC referenced to game ground. Anything more indicates a problem with these tantalum caps. You will also be able to measure DC voltage across the speaker outputs. There should normally be no DC voltage across the speaker outputs.
The LM1875 may also run very hot. Normally, you can grasp the heat sink without burning your hand. It will be hot, but not so hot that you can not squeeze it or grasp it very long. If the heat sink is so hot that you can not grip it, failing tantalum caps should be suspected. If after replacing the tantalum caps the popping and scratchiness persist, the LM1875 amp may have been damaged.
