Tutoriel Approvisionnement de contreplaqué pour plateau
RacingMat
à fond !
bonjour,
je vous partage mes recherches en cours pour approvisionner le contreplaqué pour réaliser un plateau :
épaisseur conseillée :
par les ricains 1/2" -> 12,7 mm
http://pinballmakers.com/wiki/index.php/Construction
17/32" pour le poncer à 1/2"
For hobbyists, the best option is Cabinet Grade plywood, preferably from a lumber yard, with a minimum of seven plys but a preference for nine - the more plys, the more stable and flat. This type of plywood will have a thicker top and bottom ply suitable for sanding. It will generally be the softer maple but for one-off games, it should prove acceptable.
par chez nous 15 mm
nombre de plis !
9
conseillé (7 pas assez)
on vérifiera l'épaisseur de la première couche : ctp d'hypermarché = trop fine
ctp 9 plis = la première couche est épaisse
What kind of wood are CPR's playfields made from?
http://www.classicplayfields.com/faq.html
CPR only uses the very best wood we can get our hands on. Currently we use a very expensive custom made wood from Wisconsin. It has four layers of Maritime Hard Rock Maple and three interior layers of white ash. Normal Stern wood is a .5325" thick with one good face of 0.060" veneer. We upped this specification considerably. We use two THICK 0.080" face veneers (25% thicker than normal) which allows our CNC operator, Tanner to pick the very best side for your PF and we upped the thickness of the board to 0.545" which gives a better balance with the veneers and reduces warping. The thicker face veneers on our wood (25% thicker than anything in use anywhere) means a much denser wood surface and less ball dimples than anything ever made. Some of our finished PFs weigh more than 15lbs, and are so dense we have seen certain examples of ours PFs almost double the weight of a factory NOS board!
Approvisionnement en France :
en bouleau ("birch" en anglais)
https://www.dispano.fr/panneaux/con...-faces-s-bb-150x300cm-15mm-ref-60077-A1777318
15mm -> 11 plis 40€/m² (poids 10kg/m²) https://www.dispano.fr/asset/13/97/AST2181397.pdf
12mm -> 9 plis
peuplier
https://www.dispano.fr/panneaux/con...er-b-bb-interieur-classe-1-250x122cm-A3085732
15mm -> 7 plis 20€/m² https://www.dispano.fr/asset/34/58/AST103458.pdf
je vais chercher d'autres fournisseurs pour comparer
A propos du médium
Nota : le MDF "médium" est bcp plus lourd, nettement moins rigide et a une moins bonne résistance mécanique (vissage, insert...) : à bannir !
Et vous ? vous avez des adresses ? :)
Comme on achète le contreplaqué en panneau entier (selon les magasins), il faut en trouver qui ait la bonne taille pour éviter trop de pertes
Dimensions d'un plateau de flipper : 20 à 26" par 50" = 51 cm x 125 cm environ
Pour le panneau de peuplier 125cm x 122cm à 30€ entier, ça permettrait d'en faire 2. :D
https://www.gedimat.fr/ ont l'air d'avoir du ctp de qualité, je passerai à une agence la semaine prochaine
un super article qui décrit les normes ctp : plis, collages, ctp marin, ...
et des fournisseurs
http://www.cnsl.fr/les-panneaux-de-contre-plaques/
Ah oui voilà le bon prix !
Gedimat je ne savais pas merci pour l'info
► après vérification, GEDIMAT propose du Joubert mais que du 7 plis :
Contreplaqué intérieur Combi Peuplier/Okoumé COMBIPLAK ép.15mm larg.1,22m long.2.50m
Faces Epaisses 13/10
Contreplaqué tout Okoumé MARINE PLY ép.15mm larg.1,22m long.2,50m
et pas ce 9 plis...
Contreplaqué tout Okoumé SUPER MARINE PLY ép.15 larg.1,22 long.2,50m
REF.25916676
JOUBERT PLYWOOD
► Là un contreplaqué sympa car il a une finition poncé et primaire d'accrochage blanc
https://www.joubert-group.com/fr/joubert-gamme-27-joubert-primed.html
je continue la quête... :)
Laisse tomber
Fait le plateau en fer :p arffff
Qui sait si ton flipper est fun tu peux en revendre lol
Oui mais on apprécie aussi les dons :p
Donc achete tes planches etc. ... rachète sur RP des lances bibilles (qui sont totalement chromé maintenant) et tu nous livre nos deux jeux
Il te restera une planche alors MDRMDR ou pas si tu en rates un, il faut du spare souvent :p
arfff :D
je vais aller sonner chez des fabricants de coffrage, voir s'ils n'ont pas une petite chute ! la plaque entière c'est pas le bon plan pour un seul flipper
Pas donné surtout pour un premier jet
BOnne idée
Vas voir les menuisiers (s'il en reste), justement ceux qui coffrent des Dalles (des fois du très bon marine ...) ou alors de la récup SNCF, les planches de fond de Wagon
Hi Hi ils font des promos de fond de wagon pendant les grèves ?!! raousss
PS : c’est malheureusement bien vrai qu’il faut du spare...
Je vous tiens au jus !
PS 2 : la vidéo devrait arriver lundi je dois encore debugger le lien règles et animations lumineuses et j’suis pas là de tout le WE...
je suis passé chez DISPANO ce matin : ils ont du CTP 15mm 11 plis revêtu d'un film lisse, en petit format (2m50 x 1m25) soit 60€ le panneau
https://www.dispano.fr/asset/07/39/AST230739.pdf 20€ ttc/m²
https://www.dispano.fr/panneaux/con...bi-exterieur-collage-wbp-1250x2500mm-A3036310
avec un panneau, ça ferait 4 plateaux de 125cm x 60cm à 15€ et 8 kg chaque
sinon PointP propose aussi ce ctp 11 plis
https://www.pointp.fr/gros-oeuvre-b...erieur-collage-1250x2500-mm-ep-15-mm-A3036310
à 26€/m² plus cher mais peut-être plus proche de chez vous ?
Heu ou vois tu du bois ?
Moi je vois rien du tout !!!
Ah oui je viens de voir aussi
Cela va couter un bras à mon humble avis
Par contre la surface est surement traitée spécialement pour les coffrages en béton, donc pas utilisable pour un jeu
Enfin je pense
oui, je suis curieux de toucher cet état de surface : si ça se trouve ça peut faire une bonne surface bien lisse pour poser le décor
ou bien inutilisable car impossible à coller ou peindre...
je continue à zieuter des flippers en panne sur le boncoin ça serait plus simple pour moi d'éviter de tout refaire de zéro pour me concentrer sur la programmation et l'électronique :)
A mon avis c'est un revêtement spécial dessus le truc noir, un peu comme les planches de remorques
A mon avis ce sera ce genre là
J'ai trouvé une référence "contreplaqué MDO" sur http://www.Veuillez relire dument la charte, merci/wiki/Restauration_caisse
et ça m'a orienté vers GARNICA en Espagne qui fait ce ctp de qualité : 7 plis pour du 12mm ou 15mm
avec deux faces revêtues MDO
http://duraply.one/wp-content/uploads/2018/01/Durapaint_FR.pdf
Même pour refaire une caisse, c'est du temps de gagné : la surface du Duraprime est déjà apprêtée avec un primaire...
Parque de San Miguel, 10 - bajo26007 Logroño, La RiojaEspagne Tel. : +34 941 51 19 82Fax : +34 941 51 23 57sales@garnica.one www.garnica.one
