Jumpers pour prom sons 8 ball deluxe
  • Auteur de la discussion Auteur de la discussion largo9
L
largo9
Salut, je viens d'acheter sur RP les prom sons pour mon 8 ball deluxe que je suis occupé à restaurer...
Il n'avait pas de carte son, j'ai réussi à en avoir une mais ce n'est pas celle d'origine. Comment mettre les jumpers avec ces mémoires?
Ci-joint photo de la carte.
Merci pour l'aide
If U1 CPU is a... ...then jumper this way
6802 install K, remove L, remove U6 RAM
6808 install L, remove K, install U6 RAM
-- If any of U2 through U5 are 4K (2532/9332/2732), then install
jumpers C and E, and remove jumpers A and B. If only 2K chips
(2716/9316) are used, then install A and B, and remove C and E.
-- Original schematic has an error in the jumpering notes for
2532/9332: they neglected to list jumper "D" as needed.
If U2 is a... ...then jumper this way
9316 ROM or install D and P, remove F and G
2716 EPROM
9332 ROM or install D and G, remove F and P
2532 EPROM
2732 EPROM install F and P, remove D and G
If U3 is a... ...then jumper this way
9316 ROM or install Q and T, remove R and S
2716 EPROM
9332 ROM or install Q and S, remove R and T
2532 EPROM
2732 EPROM install R and T, remove Q and S
If U4 is a... ...then jumper this way
9316 ROM or install U and X, remove V and W
2716 EPROM
9332 ROM or install U and W, remove V and X
2532 EPROM
2732 EPROM install V and X, remove U and W
If U5 is a... ...then jumper this way
9316 ROM or install Y and BB, remove Z and AA
2716 EPROM
9332 ROM or install Y and AA, remove Z and BB
2532 EPROM
2732 EPROM install Z and BB, remove Y and AA
If speech is... ...then jumper this way
Required install J and remove H
Not required install H and remove J
If U12 is... ...then jumper this way
Present remove EE jumpers (5 of them)
Not present install EE jumpers (5 of them)
If game is... ...then jumper this way
Centaur remove FF (requires AS-2518-61B)
Not Centaur install FF (if using AS-2518-61B)
If volume is... ...then jumper this way
CPU controlled install M and CC, remove N and DD
(this is normal)
Remotely controlled install N and DD, remove M and CC
ça a l air compliqué mais pas plus que ça en fait....
merci pour l'info,
pour u3 u4 et u5 c'est bon... je n'ai rien en J et j'ai en H, je change?
pour le volume j'ai N et DD je fais quoi?
install j and remove h if speech is needed
le 8bd parle donc oui il faut j et enlever h
pour le volume c est bon j ais le meme sur le FG
Tu les as prise en 2532 et 2716 le kit
Soit il faut faire cela et ce uniquement :
838-08_3.532 - U3 for Squawk & Talk, 2532 [D446]
838-09_4.716 - U4 for Squawk & Talk, 2716 [1639]
838-10_5.532 - U5 for Squawk & Talk, 2532 [3365]
AS-2518-61A (S&T) jumpers:
2532: C,E,D,G,Q,S,U,X,Y,AA
